Hi Tom
I just changed my bearings and had no trouble. My hands were too covered
with grease to take pictures. We are going to have a bearing party 'real
soon now' and I will be taking many pictures with a cam-corder and a digital
camera.
I pulled my hubs off the knuckles with a slide hammer ($69.00 Canadian mini
dollars) then removed the knuckle.
The biggest job was jacking up the coach and finding enough blocks to get
all the wheels off the ground (I was doing a complete brake rebuild at the
same time).
The second biggest job was removing the stupid bearing retainer bolts.
The actual job of pulling the bearings off the hub was quite anti-climatic.
One hint that some may find helpful is to use a nut for threaded rod to
connect 2 sockets together to hook to the square drive on the end of the
puller. Just drop a 1/2 inch drive socket onto the puller hex end up, drop
the long threaded rod nut into the socket and then use another socket to
turn it all. When you put the two sockets and long nut together you
effectively have a 1/2 inch square drive to 1/2 inch square drive.
Dave Mumert
----- Original Message -----
To:
Sent: Friday, August 18, 2000 4:21 PM
Subject: Re: GMC: Bearing Tool Instruction
> Fact is I have not started it yet as this is the busiest time of the year
for travelling and doing work on my own coach. The fact is that the
instructions on Billys site are excellent for someone that has done
mechanical work like this before. There are some fine points that need to be
clarified and when I get a chance the end of this summer I will take the
pictures and complete it. I still need a hub to use for it, and as yet have
not been able to find one to use. I do not want to take mine apart just to
do this as they are all new. Anyone got one they dont need? Send it to me
please. I also still need to make the adapter to remove the hub from the
knuckle using the OTC927.
> regards,
> tom
> >>Assuming by now you've written and posted the instruction, and that I
> >>missed it, could you (or anybody who knows) tell me where I can find it?
TIA
> >hehehe...... Dave, if your not a politician, you missed your calling!
> >bdub
> >To unsubscribe, e-mail: gmcmotorhome-unsubscribe
> >For additional commands, e-mail: gmcmotorhome-help
