> Can anyone shed some light on why a drive axle nut would loosen?
> (Patrick, didn't you once mention your coach had a loose nut when you
> checked it?) Sleep's going to hard to find until I hear some response
> to this puzzle.
Phil,
Yes I did find this(along with other nightmarish surprises) when I
rebuilt my front end. The only plausible explanation(other than
incompetence) I've come up with is the possibility that some trash was
allowed behind the axle and after the coach was run a few miles, this
was ground up and allowed the play. This is a documented problem with
ball joints. In my case though, it wouldn't surprise me that the
bearings were improperly installed(some room left between the bearings
and then they pulled together under load).
One thing I plan to do after driving the coach a couple hundred miles is
retorque the axle nuts to be sure.
Patrick
Patrick Flowers
Mailto
atri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
> to this puzzle.
Phil,
Patrick
Patrick Flowers
Mailto
