Two 12 V batteries (starting and House)in the front engine compartment on
a double battery tray and another 12 V battery in the Onan generator
compartment for starting the generator.
I 've read about increasing the booddocking time by replacing the 12V
house battery with 2 6v Golf cart batteries wired in series which provides
considerably more amp hours. Where does one put them? There doesn't seem to
be room in the front passenger side engine compartment where the two 12v
batteries are now. If I put the House battery(s) back in the Onan
compartment, what additional wires do I need to run and what size. Would
there be a problem with weight, I understand that the front end is already
too light.
I also have read that putting dissimiliar batteries in the same charging
circuit will/can result in one of the batteries receiving insufficient
charge. It would seem I can't/shouldn't use the existing charging circuit,
which now charges the two front batteries simultaneously, with a 12V battery
on one terminal of the isolator and two 6v batteries on the other terminal.
I've got the full set of manuals but the wiring diagrams do not show the
generator wiring - at least I've missed it if they do.
We got the MH in August and this is the first time I've gotten free time to
start looking at this. I retired two years ago and have been so busy (Not
with Work!) I haven't been able to get any time to get the MH setup. : )
John
too light.
John
