Strange things cropped up yesterday. I was going to take the Avion on a day
trip to my Brothers 17 acre Ranch to use the generator. He was burned out of
home and shop in the fire in Vacaville Ca. Completely torched- total loss.
81 years old so he is not going to start over, but they are ok (and so is
the cat they grabbed). They are also well off and now can move anywhere with
no baggage.
But I digress. I had started the 3 way refer by cycling thru the electric,
then to propane. No problem with refer as it cooled. Next morning, Went to
start the coach and nada. Both front house and truck batteries were dead.
I put a commercial car lot style charger on it, went from 2 amp to 15 amp to
60 amp, and as I switched up, the whine from the rear radio speakers got
louder and louder. And I could not increase the voltage going into the
battery above 8.5 to 9 volts. An hour worth of charge did not change
anything.
The charger on the house battery did not produce the feed back in the radio
speakers and started to charge normally.
I suspected first that for some reason, the selection of 12 volt to the
refer has stayed on and run down both batteries. Can this happen?
I kinda now suspect that my truck battery has shorted and ran down the house
battery.
I went to the ranch to help doing things that did not need the generator in
another vehicle. Left the battery charger on the truck battery all day and
it did NOT take a charge.
Any conclusions leap to mind regarding the radio whine, the failure of the
battery to take a charge or if the 12 volt system can stay on when switched
to proipane?
DeanHanson
75 (produced in Nov 74) Avion twin bed.
no baggage.
anything.
battery.
to proipane?
DeanHanson
