I ran a large welding cable from front to back. Put in one of Applied 3 battery trays up front. So, I have 2 house battery's up front. And 2 in back. Next, I put in an invertor in the back closet. Then I ran a 110V invertor circuit up each side of the coach. To 7 wall plugs on each side. Those 14 duplex wall plugs. All have shore/gen duplex wall plugs. And 12V/USB wall plugs. All these are in triplex wide wall boxes. The Shore/gen 110V are controlled by an automatic transfer switch.
The 15 LED flush mount ceiling. And under cabinet LED, flush mount lights. Are on wall/house type wall switches. You can come in. Turn the lights on next to the entry door. Go to bed. And turn the lights off by way of wall switches that are next to the beds. The MAX Fan ceiling unit. Can be set to the temps that you want. Thus, will turn on, or off as required. And that is all controlled by a remote.
And yes. All this required a huge amount of extra wire. That's pact in with added wall/ceiling insulation. Hate extension cords.
Bob Dunahugh
78 Royale
Bob Dunahugh
78 Royale
