Hey, how is this for a modification. The way I solved the problem of having
only one dump tank was to take the toilet out. I used a stainless steel
cover and siliconed it over the hole. It looks fine, besides it is covered
with the potty. I put a plug on the water line and pushed it through the
hole. The toilet had a little silver plug that covered the water line hole
in the wall perfectly. I then bought a nice cushy port a potty and put 1/2
inch rubber feet on it so it clears the old toilet opening, which sticks up
about 1/4inch. What I like about this arrangement is that I can take the
potty out of the shower for more room, and I don't have to worry about
running out of capacity as I can drain the gray water on the ground. (I live
in the country and water my apple trees with it.) Also I do not have to go
to a dump station to empty my coach. A toilet will now suffice.
Of course I saved the toilet just in case I change my mind, or if I sell the
coach, I have the option of putting it back to original.
David
75 Palm Beach
David
75 Palm Beach
