Backup camera - Haloview MC7108
Christo
Administrator
Staff member
Oct 4, 2019
1,594
1,019
113
Weymouth, MA
www.cruzingear.co
I've been running a Haloview MC7108 wireless backup camera system for a couple of months and it's worked out quite well. I also purchased a mount so that I could install the monitor in place of the rear view mirror. A lot of folks power their backup cameras from the backup light circuit, but I decided to tie into the parking light circuit instead (specifically the clearance light wiring in the front and the rear) so that I could have the option of using the camera while driving. Unfortunately with the camera installed above the rear window it only shows about 12 feet behind the coach while keeping the rear bumper in view. It does, however, provide a good view to the sides so I can tell if there's room to change lanes. Just keep in mind that there's a slight delay in the video, so if a vehicle in an adjacent lane is gaining on you, there may be less room to change lanes than you think!
The monitor supports up to four cameras, so it's worth considering having two cameras in the rear, one pointing down and one pointing back. You can also install a microSD card in the monitor to record everything the camera(s) sees. The 720P high-def camera is amazing, it has excellent night vision, and the lens supports a 120 degree viewing angle -- good coverage without being so wide that the distortion makes it hard to judge distance. Good stuff.
Reactions: MisterD
Not much info available, PO installed them. Jim Bounds at Cooperative Motor Works might know because there are several mods to this coach from Clasco and he was part of that business. They have red backlighting at night. Also, vacuum gauge is labeled 'turbo boost'.
Thanks for the detailed report. Have you had any of your recorded videos on the computer yet? If so, I'd be curious to see what some screenshots look like.
Here are a couple of videos, one nighttime with IR illumination and one daytime. Note, I had to convert from .AVI to .mp4 in order to upload to this site, and the camera is configured for mirror mode so that it works as expected as a rear view mirror (the coach's ladder appears on the right instead of the left).
View attachment Haloview Night.mp4
View attachment 174519_4.mp4
That's awesome! I'm pretty impressed with the night time video especially. Thanks for sharing, that's a great demo. That looks like a great, flexible system. Now I just have to justify the expense some time down the road.
Reactions: Christo
It looks like they're reversible. You'd want to mount them at the front pointing back for lane change/parking usage. I prefer good mirrors. Yeah the gauges are pretty cool but I don't know where the PO got them. No brand name on front or back, and unfortunately the vacuum gauge says "turbo boost." Good conversation starter when people tour the coach, though!
Reactions: MisterD
YOUR RIGHT ABOUT THE ANGLE OF VIEW AND NO REFRENCE TO CENTER OR LEFT AND RIGHT. I NEED A REFERENCE POINT TO DETERMINEW WHERE THE MH IS IN REFERENCE TO THE GROUND AND IMMOBILE OBJECTS.
Where is the rear camera mounted on the back of the coach? I'm working on installing a system but not sure if I want to put screws through the top of the rear cap, or just mount the camera to the top of the spare tire cover.
Top center, which required removing/replacing the interior shell. The high camera angle helps to see the corners of the coach but it only shows about 15 feet behind the coach so it's only for backup, not so much for rear view. If I were to do it again I'd put two cameras up there, one aimed down and one aimed back. Spare tire mount is a possibility for sure, or even inside at the bottom of the window. Try several locations before committing and see what you like best. Whatever you do, it's a good idea to keep it in the center.
Reactions: Bob Dunahugh
Thanks Christo!
I got a Haloview and the side cameras for my Airstream trailer to replace the oe camera. I like the resolution and system, however the wireless delay can be a problem. For the GMC, I got a wired rear view mirror with a front view camera and DVR. AKASO DL12 2.5K Mirror Dash Cam...
Sofar, I like it however I am thinking of mounting it at the top right of the instrument panel..... sort of on the same plane as the side view mirrors. I find looking up at OE mirror position a little akward. The backup function connected to backup lights is great. One problem, cable for camera is a little short.
Reactions: Christo
