Back Wheel Bearings
marlene meineken
1,859
HELP EMERGENCY
We are doing our BACK WHEEL BEARINGS so far we have the Front (outside )
Bearing off but can't figure out how to remove the rest of the parts, inside
Bearing etc. We are just Greasing. (but want to check Bearings for wear
etc.)
Can anyone explain.
Marlene Meineken
Marlene,
You have to slide the brake drum/hub assembly off the spindle. You may
have to adjust back the brake shoes to get the drum off. Do you have
the Maintenance Manual? The procedure is spelled out in there I'm
sure. Once you get the hub off, you have to remove the real seal(buy
new seals) to get the back bearing out. Clean up the hub, bearings and
races with mineral spirits(don't get any inside the brake drum) so you
can examine for wear. Repack and replace per the manual. You might
want to visit the Timken web site for tips on setting bearing clearance
if you have a dial indicator handy. If not, set up per the manual.
Patrick
> HELP EMERGENCY
> etc.)
> Can anyone explain.
> Marlene Meineken
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
We do have the drum assembly off . We were hoping to reuse the seals. but
don't understand how to remove the seals without ruining them. No we don't
have the right manual for this procedure.
To reinstall etc. we will be using a regular torque wrench it's all we have.
Marlene
To:
Sent: Sunday, June 04, 2000 12:46 PM
Subject: Re: GMC: Back Wheel Bearings
> Marlene,
> Patrick
> > HELP EMERGENCY
(outside )
inside
> > etc.)
> > Can anyone explain.
> > Marlene Meineken
> Patrick Flowers
> Mailto:patrick
Ok just tell us how to get the rest apart.
Marlene
To:
Sent: Sunday, June 04, 2000 1:24 PM
> In a message dated 6/4/2000 3:56:19 PM Eastern Daylight Time,
> Hi Marlene!
> Re-use seals? Very difficult to remove without distorting somewhere. Best
to
> replace seals for the cost and peace of mind are well worth it. Bearings
if
> ok can be cleaned and repacked with grease.
> Scott NEHODA'S
> BACK YARD
Marlene,
Once you've removed the grease seal, the inner bearing will come out. If you
are cleaning and re-using the bearings, there is no need to remove the races
from the hub. Clean, inspect and re-pack just like Patrick described in his
post.
This is what I found on Gene's website about rear wheel bearing torque, read
carefully:
"REAR SPINDLE NUTS
The Maintenance manual is very mis-leading on how to tighten the rear
spindle nut. The 25 ft-lbs is only the initial torque to seat the bearing &
then it is to be loosen & re-torqued to finger tight or less. Over torque
of the spindle nut will lead to a very hot bearing very quickly. I have
seen the spindle shear off on several coaches that were torqued to the 25
ft-lbs level & left there (the wheel passed the coach as it slowed down).
Big $$$$$$ repair.Duane "
Good luck,
Peter
Colorado
To:
Sent: Sunday, June 04, 2000 2:26 PM
> Marlene
> From:
> To:
> > Hi Marlene!
Best
> to
Bearings
> if
> > Scott NEHODA'S
> > BACK YARD
Our biggest problem is that the rubber seal with metal ring is very tight
and doesn't want to come out. What is the best way to remove it???
Marlene
To:
Sent: Sunday, June 04, 2000 2:01 PM
> Marlene,
you
races
his
> post.
read
> carefully:
> "REAR SPINDLE NUTS
> Good luck,
> Peter
> 77 Eleganza II
> Colorado
> From: "Marlene Meineken"
> To:
> > Marlene
> > From:
> > To:
> > > Hi Marlene!
> Best
> > to
> Bearings
> > if
> > > Scott HREF="http://members.aol.com/adohen/advice/index.htm">NEHODA'S
> > > BACK YARD
Thanks Scott
Don't have a seal remover but do have a 100 screw drivers.
Marlene
To:
Sent: Sunday, June 04, 2000 2:14 PM
> In a message dated 6/4/2000 5:09:33 PM Eastern Daylight Time,
tight
> I use a seal remover:) however you can pry the seal loose with a long
crow
> bar, screwdriver, etc. The main thing you want to be careful of not
doing
> is scouring any finished surfaces on the hub when trying to remove the
seal.
> Scott http://members.tripod.com/adohen/ t=_self] [/url]I HREF="http://members.aol.com/adohen2/page/index.htm">NSIDE GMC
PHOTOS(sound
> on?)
Marlene,
If you don't have a seal remover, try this:
Lay the drum on the ground, seal facing up. Spray with some penetrating oil
where the seal meets the hub. Now tap one side of the seal (metal ring)
lightly using a punch/screwdriver and a hammer - that should break the seal
loose from the hub. You shoud be able to pry the seal out of the hub using a
bar/large screwdriver. Be careful not to damage anything.
Peter
Colorado
To:
Sent: Sunday, June 04, 2000 3:07 PM
> Marlene
> From: Peter Brandt
> To:
> > Marlene,
> you
> races
> his
> > post.
> read
> > carefully:
> > "REAR SPINDLE NUTS
bearing
torque
25
down).
> > Good luck,
> > Peter
> > 77 Eleganza II
> > Colorado
> > To:
> > > Marlene
> > > From:
> > > To:
> > > > Hi Marlene!
> > Best
> > > to
> > Bearings
> > > if
> > > > Scott > HREF="http://members.aol.com/adohen/advice/index.htm">NEHODA'S
> > > > BACK YARD
