> Your signature says "Hughes" which means I have no direct experience. However, just as a point of reference the GMC upfit coach runs both ACs
> anytime - on generator or shore power with a OEM 50 amp cord. My Royale runs only the center AC on a 30 amp shore power cord, but will run both on
> the generator (with an additional from Coachmen fuse box). So would recommend you keep discovering your existing situation or have an expert
> decipher it. If you look on BDUBs gmc site for manuals, you can get the Coachmen electric wiring diagrams and see if they tell you anything
> helpful.
> Yet another solution I have seen is leave the main AC wired in a typical fashion, and the second (usually rear) air hard wired to a 20 amp plug
> that is plugged into a shore power connection when both a 30 amp and a 20 amp are available on the same pole. Someone else can comment if that
> actually provides two sources of power, but I'm just saying it has been done that way.
Yah i have Coachmen and Avion schematics which help but not the Hughes..... so i just try to piece it all together. I think both a/c units will work
off the 30amp source (if i go that route) though npt that i think id run them both at the same time....lol.
Rich Mondor,
Brockville, ON
77 Hughes 2600
> helpful.
Rich Mondor,
Brockville, ON
77 Hughes 2600
