It's certainly possible to insert a tee and a pressure sensor in the line
feeding the carburetor. But, it seems to me much better to follow the most
economical technique: Do a binary search: Go to the middle of the system
and see whether the problem is before or after that point. Then go half
way toward the problem, etc., etc. They've already begun that process
with the external fuel tank -- the problem's aft of where they tied that
in. It's probable that one, at most two, more tests will clearly determine
the location: Insert the external tank before and after the selector valve.
JMHO,
On Mon, Sep 4, 2017 at 12:11 PM, John Phillips
wrote:
> I like the pressure gauge but could also see a vacuum gauge just before the
> fuel pump.
> Instrumentation was my background. If you get an indication where the
> problem is you have less of a system to troubleshoot.
> Is there a safe way to have a permanent fuel pressure gauge at the
> carburetor, preferably just before the float?
> On Mon, Sep 4, 2017 at 7:47 AM, Randy Cohen/Catherine McGinley <
> > I saw pics of people putting a flare on the end of the pickup but that
> > looked too hard. I just used a short section of rubber hose and hose
> > clamps.
> > Your problem seems to be very challenging, all the usual trys have not
> > improved things. Maybe a pressure gage right before the carb would help
> > quantify and maybe show some new info.
> > Good luck.
> *John Phillips*
JMHO,
> fuel pump.
> > clamps.
> > Good luck.
> *John Phillips*
