seen no adverse affects from blocking them
off. Even when it was in the low 40s in MI. I did
put on an electric choke.
" The only "problem" I have had on this trip was
twice when I was pulling long hills the secondaries
were howling real good the engine seemed to
surge 2 times and go on. I dont think it was a high
speed miss."
Long hills............secondaries.............howling real
good...............
Sounds like your having fun...........keep it up................
but what you are describing sounds to me like it might
be loss of fuel pressure when you have too much fun
for too long.
Don't you have an electric fuel pump hooked to a
primer button?
If so easy to find out if loss of fuel pressure is the problem.
I suspect that if on the next long pull you hold that button
down you won't have those 2 surges
Regards
Gary Zingle
1973 GMC 26 foot
speed miss."
good...............
for too long.
primer button?
Regards
Gary Zingle
1973 GMC 26 foot
