I worked on a modified GMC Coach a few years ago that had a 455 Olds that
was extensively modified. It had a Howell EBL installed that was never
"optimized" for the extensive modifications that had been done. The owner
was not completely happy with the way it ran. I agreed to look at the coach
to see if I could do anything with it.
The first thing I noticed was the throttle had a bunch of slack in it
that had to be taken up before any change in engine speed. Upon close
inspection, the inner throttle cable was too long, but if I shortened it
up, it would not open fully. So, I fabricated an adjustable outer cable
retainer that could be moved fore and aft to optimize the movement and
still reach wide open throttle. The installer had installed a return spring
that rivaled a hood spring. It was very difficult to press. A stock
quadrajet double spring cured that. The engine had a "flat spot" at low
speed that was not acceptable. A few phone calls to Howell proved some
help, but, "no cigar". Then, I called Randy VanWinkle and Bob R. at EBL.
They guided me through several "binfile" changes, and with my trusty laptop
and numerous drive tests, we woke that 455 up.
Really, on dry smooth level asphalt, it would burn the tires all
through 1st gear, chirp 'em on both of the other shifts. 3:55 final drive,
stock size tires on Alcoa wheels. Never checked fuel economy. The customer
always towed a car, and never complained about a lack of power. That is a
good outcome in my opinion. Your results may vary.
> I think it's a lot. I put my installation off way too long. Someone asked
> me if EFI is a necessary upgrade. I truly can't say that any upgrade is
> truly NECESSARY. My list of upgrade that I LIKE are. EFI with spark
> control, 3:70 FD, greaseable front wheel bearings without taking the
> bearings apart, front rear axle disc brakes, and a Sanden A/C compressor.
> Bob Dunahugh 78 Royale
