Another reason for a back-up brake pump
Matt Colie
11,101
807
113
South East Michigan near DTW
Well, we went to out first rally since Manfield. There was an interesting situation when the coach was almost there.
When checking in, I stopped at the little building and talked to the nice lady and pulled away. There was quite a rise and just before the crest, the
engine sputtered and died. From the sound of it, it was vapor lock. I tried to get our old dog off the engine hatch because I have cured this before
(years ago) by getting the carburetor cooled off fast.
Problem: The old dog did not want to move. It took me much longer than I like to get the hatch open. When I finally did, the carburetor was dry
almost totally dry. The accelerator pumps didn't do much. I had no simple way available to get fuel from the system and pour it into the carburetor.
I should also mention that the Chaumière was full of year old winter gas.
Needless to say, I had time to think. As I sat in the sun, and calculated the time to local sunset, it also occurred to me that we where head up by a
lot and in the sun. If I could roll the coach back down the slope and through the gate, we could be A: Out of the Sun and B: Much closer to level.
This was a maneuver with some risk. I knew I could back the her on the mirrors, and the added vacuum pump should give me brakes enough to control the
situation.
BUT, I had installed the that vacuum pump years ago and never had an occasion to really test it. My parking brake does sort of work, but I didn't
want to try that here in the case that it did not release.
So, I turned on the ignition and cycled the brakes to hear (just barely - me not the pump) the little pump run and the brakes felt good. I got my
mental picture of the situation well defined and held the brake while I popped the transmission out of Park.
The backward roll was completely controllable to hold the speed down, I was on and off the brake and the pump was there for me.
We settled into a shady place and I pulled a bottle of water out of the reefer and listened to music for about 15 minutes give or take.
When I thought I had a good chance, I engaged the battery boost (on a 73, this is not a momentary) and started cranking. It took about 15 seconds for
the first fire and then they kept on coming and she was soon at a stable idle. So, I started back up the hill and this time I had no problem making
it to the campsite.
I do actually have a boost pump. I acquired it years ago and it is still under the dinette seat where it is safe. Maybe I will bump that priority a
little and try to burn off the year old winter fuel.....
Matt,
Sorry to hear about your fun at the gate the other day. I had similar problems (not related to vapor lock, but an ignition problem that I ultimately
solved) on a trip to Reno a few years ago. I had previously installed a vacuum system put together by Dave Lenzi. As a result I had no worries about
not being able to stop in the mountains or any other place and there were about half a dozen times she quit. I previously had the JC-4 pump that's
been recommended by various GMC people until I did a little test.
http://gmc.mybirdfeeder.net/GMCforum/index.php?t=msg&th=39705&start=0
I'm curious as to the pump you have?
Richard
SE Michigan
www.PalmBeachGMC.com
Roller Cam 455, TBI+EBL, 3.42 FD, 4 Bag, Macerator, Lenzi (brakes, vacuum system, front end stuff), Manny Tranny, vacuum step, Tankless + OEM water
heaters.
Matt,
Thank you for sharing. I have the fuel boost pump switch on the left side dash cover below the steering column. On this new rebuild, I will put it
back there for the reason you described.
I also have the vacuum back up pump, but will check it periodically. I am wondering if I should include a dash vacuum guage for the back up vacuum
pump?
You guys sharing all these experiences is very helpful and for that and more I thank you.
I am glad all worked out well.
Safe travels and thanks again,
Tom K.
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
Richard,
I do not recall which pump it is, but it is not the JC-4 and it is not the pump that Ford bought from Bosch for their electric cars. Even with the
coach just outside my window, it is rain hard enough to make me wait before I go out there, but I will get back to you.
