> Improper grounding will bite you frequently and people do not stop to consider it. What makes ours worse is we have 3 separate grounding systems
> in a GMC and most people do not stop to consider them.
> I did a demonstration one time for Dan Gregg. He attached a ground wire to the base of his Paterson Distributor and ran it to battery negative.
> I told him not to do it but he disagreed.
> The demonstration was to disconnect the starting battery negative cable from the engine block. Upon attempting to start the engine he promptly
> smoked the 12 ga. wire between the distributor base and the battery he had just installed. We replaced the wire and ran it to the engine instead of
> the battery.
I missed that show. I heard your talk at Elkhart, but I missed that show.
> the battery.
