Air Filter for Onan 6000kw in GMC - FOUND
emerystora
14,608
2
1
My thanks to Mike Hamm. I went to Lowes and found an exact fit for the Onan filter.
Look for a bright yellow filter as it came with a yellow foam outer wrap that can be removed for cleaning.
It is labeled as a Briggs & Stratton Air Filter/Precleaner.
It is part number 793569/793685.
The UPC code on the package is 0 2484761889 1.
The price was approx. $18.
It fit right in with no modification to the rod. I used a larger fender washer on the bottom as the bottom was fiber instead of steel.
I had to drill a hole into the center of the bottom for the rod.
KIM please include this part in the GMCMI Parts Interchange booklet.
Emery Stora
77 Kingsley
Frederick, CO
> I bought a filter from Lowes that fit. I am not sure what it was for, so sort of tractor they sell. It is the same length and diameter just had to
> drill a hole in the plastic end for the rod.
> 1977 Kingsley 455 as stock as it gets except lots of Ragusa parts
For those that do not want to look around, we stock the correct Onan parts .
For some, they rather order a correct part and pay more than horse around.
Nothing wrong trying to save funds.
If you go to our site, you might learn that there are few accessories that
can improve your Onan and your coach. www.appliedgmc.com
> > Onan air filter replacement with same #'s as Emery posted:
> > https://www.amazon.com/gp/offer-listing/B01N8VIXQR/ref=
> dp_olp_0?ie=UTF8&condition=all
> Yea that's the one and much better price than lowes.
http://www.appliedgmc.com
Yes, Jim Kanomata (Applied GMC) stocks most of what we need for our GMCs and when we buy from him we know it wit fit and is the right part.
I did not buy it from Lowe’s to save money but I needed it the same day so that I could replace it and use my GMC the next day. My Onan was starving for air as I had been neglecting to change the filter and I was planning on using the Onan for dry camping.
Emery Stora
77 Kingsley
Frederick, CO
