Air compressor
james bolick
164
Whoooa Arch, that's a lot of money for an air compressor, I damn near
fainted. This is my solution to the problematic small air compressor on my
GMC. I replaced it three times in as many years and at $240.00 a pop, I got
disgusted. All the lines , hardware and last broken pump is still installed
on the coach. I disconnected the air lines at each air bag and installed
schrader valves. Went to Lowe's hardware and bought a small DeVilbiss air
compressor, 1.5 h.p. with a 3 gal. hotdog tank. Pumps up to 125 p.s.i., it
weighs about 25 lbs., I carry it in the trunk of my toad or in the bench
seat storage area. Did that about 6 years ago. I'm one of the few GMC
owners I've talked to that has had lousy luck with the small air
compressors. I run with 75 lbs. in the passenger side air bag and 80 lbs.
in the driver side air bag.
Jim Bolick
'73 Painted Desert
Jim didn't the '73 get its air from outside the caoch and without a filter?
>Jim Bolick
>'73 Painted Desert
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
