Air cleaner - Follow up
blank
1,525
Chip,
The only thing I know of that will work is an air cleaner off a Toronado
through 1978. Only problem is that the Toro air cleaner will be about 1/2
inch higher than the original motorhome air cleaner and will interfere with
the rear of the engine cover. You can use a router to remove about 1/4 inch
of wood only where it hits the air cleaner or get one of Darren's neat
aluminum engine covers.
Patrick
> Somewhere in the geneaology of my coach the PO removed the
> stock air cleaner
> and replaced it with a simple aftermarket filter with a
> cover. There is no
> engine preheat, PCV or the typical components of the stock
> air cleaner. The
> preheat shroud over the left manifold is also missing. I
> will be making a
> trip to the local automobile part recycling facility (AKA
> junkyard) this
> weekend. What should I look for? Will a standard air
> cleaner for any GM
> auto/truck from that erea work? How about the preheat shroud?
> Chip Gremillion
> 75 Glenbrook
Somewhere in the geneaology of my coach the PO removed the stock air cleaner
and replaced it with a simple aftermarket filter with a cover. There is no
engine preheat, PCV or the typical components of the stock air cleaner. The
preheat shroud over the left manifold is also missing. I will be making a
trip to the local automobile part recycling facility (AKA junkyard) this
weekend. What should I look for? Will a standard air cleaner for any GM
Chip Gremillion
75 Glenbrook
The flat cover, I now have, gives you that extra room you need to do this. No
routers involved. Darren
> Chip,
> Patrick
> > stock air cleaner
> > cover. There is no
> > air cleaner. The
> > will be making a
> > junkyard) this
> > cleaner for any GM
> > Chip Gremillion
> > 75 Glenbrook
Darren Paget
76 Experimental
Another Fab Day
http://www.TZEplus.com
