> I tried the auto on all the time once and the compressors came on
periodically.
> When I go to my destination the air bags had the coach pretty high in the
rear.
> Chuck Is something wrong here? How do I fix it? I have always used the
fine
> minute to get the height right and then turned the rocker switch to hold.
I
> have the 78 model.
If you have the electro level 1 and consistently gain height, you have leaky
3 way valves. The valves pass air pressure through from the tank into the
air bags. A small piece of gunk in the sealing portion of the valve causes
this problem. You can try to take the valve apart and clean it, with a so-so
chance of success.
The thing is that you don't loose pressure that you can find with a leak
detector, you just slowly inflate the air bags. Its an internal leak. You
have several options:
1). Fix or replace the 3 way valves.
2). Put your EL switch in the hold position.
>Justin
>Where did you get color coded air line?
I got mine at NAPA. They were reluctant to order it at my local store, so I
waited till I was in Fort Wayne and drove to the distribution center and
bought it there. They also have really nice fittings for the 1/4" line. You
might also check a truck/semi garage or dealer, large trucks have anti-lock
brakes that frequently use color coded lines.
Here's a thought: go to Radio Shack and get a pack of 6 colored electrical
tape. Put a wrap of the colored tape on the ends of the black tubing. You
can make it more permanent by putting a small ty-wrap around it to make sure
it doesn't come unwound.
Almost as good, very simple and inexpensive. Lowes Home improvement also has
colored electrical tape in larger rolls.
Mark Grady
'77 Kingsley
North Webster, IN
mgrady
periodically.
rear.
fine
I
> have the 78 model.
chance of success.
>Justin
Mark Grady
'77 Kingsley
North Webster, IN
mgrady
