Richard --
Air bag pressure will vary with the weight of the coach. You are trying to
maintain a fixed height, so more pressure may be required to do that. My '77
Kingsley averages between 80 and 90 pounds in the air bags themselves.
Your tank pressure, which is what you're seeing with that gauge, should be
80 to 120
142# is too much. Back the larger nut off on the big spring in the pressure
switch. 120# is plenty. More than that, and you'll blow out your air bags if
you use the raise setting of the EL I.
If I remember correctly, there is a smaller screw that controls the
differential. Differential is the turn on point for the compressor. Turning
it down (tighter) should make the differential less, but that can also make
the turn off point be higher. You have to kind of fiddle with it to get it
just right.
Based on my experience, you need to have the compressor turn on at 80 to 85#
to have enough tank pressure to get and keep the right ride height with a
heavier load.
Here's the reason: the heavier load equals higher bag pressure.
The leveling valves are calling for more air to be sent to the bags, but the
load on the bags pushes air pressure back into the holding tank. Then, the
compressor doesn't run.
The ride height never goes up when the compressor won't run. The compressor
won't run when the pressure switch is satisfied. The net effect is that the
ride height is too low under load, which throws off your front end steering
geometry and alignment.
All that said, I've assumed you "set level to auto" and are not a "set level
to hold" type of guy. If you're a 'holder' then none of this matters,
because your entire EL I system is turned off. If your rear air bags leak
down any at all, you loose ride height. The system can only level itself in
the 'auto' setting and maintain a constant ride height in the 'auto'
setting.
The owners' manual, the light on the dash and the people on this list are
all divided on the proper operation of the level switch.
I struggled with these concepts for a long time before finally figuring it
out. I could never consistently get the right ride height until I fixed my
pressure switch problem.
Mark Grady
'77 Kingsley
North Webster, IN
mgrady
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Richard Guthart
> Sent: Thursday, November 19, 1998 1:26 PM
> To: gmcmotorhome
> Subject: GMC: air bag pressure & adjustment of pressure switch
> Does anyone know what the air pressure is in the airbags when the coach is
> in "hold" setting at normal height?
> The reason I ask is that, after installing the Cinnebar air system upgrade
> kit for Electrolevel I, which includes an in-line gauge, I discovered that
> my compressor has been cycling on at 80psi and off at 142psi! (Spec. is on
> at 100 and off at 120 according to the manuals.)
> If I adjust the pressure switch by backing off the adjusting nut
> so that the
> compressor turns off at 120psi, that will also reduce the
> pressure at which
> the compressor cycles back on, will it not?
> I'm wondering if the system will still function normally with the lower
> cut-in pressure.
> Dick Guthart
> '77 Birchaven (still ugly but getting closer to mechanically restored)
80 to 120
just right.
heavier load.
setting.
Mark Grady
'77 Kingsley
North Webster, IN
mgrady
> [mailto
> To: gmcmotorhome
> so that the
> pressure at which
> cut-in pressure.
> Dick Guthart
