I was wondering if I can wire two fans to the nearby ceiling light, or should I run a separate line to the fuse block? The fans are rated at 1.3 amps each, so it's not that much of a draw. If you have these, how did you do it? I didn't want to use the cig lighter; I want it more permanent and hidden.
