AC Vacuum Controls
Carl Stouffer
4,693
381
83
Tucson, Arizona 85718
My coach is a '75, so the dash air conditioning airflow is pretty dismal in the first place, but there is almost no air at all coming from the
registers at the right side of the dash. I started checking vacuum to the servos and found no vacuum at that line. Working my way back, I found I
didn't have any vacuum coming from the engine to the little round vacuum can on the firewall.
Somehow, the line had come disconnected from the intake manifold. I re-connected it, thinking that would fix everything, but it is still not working
properly. Now, when I start the engine, the recirc door closes, and the heater valve closes, but there is still no vacuum at the right side servo.
Also, when I turn on the heater, the heat control valve stays closed. It looks like all the vacuum lines are hooked up to the dash control correctly,
but things are still not operating like they should be.
Any ideas?
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Yes.
Check vacuum lines to ensure they are not blocked.
Check your vacuum mounting at the manifold to insure they are correctly
hooked up.
Is the vacuum “manifold “ at the hvac box hooked up properly and the lines
not clogged?
Check your vacuum parts on the hvac box to ensure they are free moving and
check your door linkages to ensure they work properly.
Check the cables comping from the controls to the box. Ensure they move
fully.
Sammy
On Mon, May 27, 2019 at 19:31 Carl Stouffer via Gmclist <
> working
> Any ideas?
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Eagles,
Carl,
Sammy could be right, but before you do much else, pull on the rubber connectors everywhere. I have had two of them split. They looked great, but I
could not see the split until it was stretched.
If it is a problem with the selector valve, I can't help you at all.
Do you have the diagram of the all vac lines.
I can send one if you do not have.
On Mon, May 27, 2019 at 8:19 PM Matt Colie via Gmclist <
> Carl,
> but I
> Matt
http://www.appliedgmc.com
Thanks for the advice. I will check them methodically when I get some time after returning from a two week (non motorhome) trip to Alaska.
I do have the vacuum line diagrams and now, thanks to Daniel J. I have a color version.
It makes sense that some of the vacuum lines may have gotten dirt in them and might be clogged and I have repaired some of the nipples that were
split, but there may be more. I'll look closely at those things.
Thanks again.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Use a stethoscope to trace the system starting at engine all the way through the valves to vac motors. You don't even need Ohms Law!!
John Lebetski
Woodstock, IL
