About the air bags
clark searle
76
If the bags hold pressure by shutting off the valves you
installed, you know your bags are OK. That tells you
there's a leak or leaks in the connections of the supply
lines, back at the compressor and valves, or if you have the
pre-Electro Level system, apparently the air valves on the
dash are a frequent trouble source. The leaks can be hard
to find, but usually can be fixed pretty easily. Get some
"Snoop" from a parts store or "Gas Line Leak Detector" from
Sears and spray it on all the connections (I've used only
the Sears product). In a short time there'll be a bulging
bunch of bubbles where ever there's a leak. Then either
tighten the fitting, replace o-rings or whatever is
necessary to fix it and you should be very happy with your
air suspension system.
Clark Searle
