A few things I learned this weekend
sean kidd
692
The first detent on the hydraulic wipers is intermittent...5 second delay on wipers
Buy a female hose bib to male 1/2 male npt and a hose pressure regulator, this will save you when you realize your city water pressure regulator froze
and cracked over the winter
My 455 LOVES Brad Penn oil, smoother acceleration, more power...more expensive, but worth it imo, you can find it on Amazon.
I cannot braze aluminum tubing, despite what YouTube says.
3 evaporators are much better than 1
Early models have 2 vacuum actuators just below the heater controls on the right side of dash panel, the lines are not interchangeable...PO may have
switched them, ahem.
Sean and Stephanie
73 Ex-CanyonLands 26' #317 "Oliver"
Hubler 1-Ton, Quad-Bags, Rear Disc, Reaction Arms, P.Huber TBs, 3.70:1 LSD Honda 6500 inverter gen.
Colonial Travelers
10w40...don't be alarmed by the green color.
Sean and Stephanie
Colonial Travelers
Used 30 weight break-in Brad penn then Valvaline racing oil then 15/50 Mobil one after a few thousand miles
Roy Keen
Minden,NV
76 X Glenbrook
My rebuilder told me to use Brad Penn break in oil followed by Brad Penn 10W40.
My first trip of 1750 miles required no additional oil.
He told me after 5000 miles to use either Brad Penn or the Mobil 1 15W50 that i have used in my previous engine.
I am debating on which to use in the future.
My builder builds a lot of racing engines and is really high on Brad Penn.
Emery Stora
77 Kingsley
Frederick, CO
> Sean and Stephanie
> Colonial Travelers
Wow! 3 evaporators. You are the King. Are you running A6 or new style compressor?
1978 GMC Royal
Eastern Pennslyvania
1968 Chevrolet C20 396 Camper Special
1969 Chevrolet C20 Camper Special
1985 Buick Electra Park Avenue
1992 Camaro 25th Anniversary Heretage Edition Black
I resealed my original A6, running 30psi frostycool, and still froze new evaporator....I bought a parallel flow condenser for a sterling, but it's 1"
too wide, so I'm still running stock condenser. I'm probably at 90% of the A6 capacity.
Sean and Stephanie
Colonial Travelers
