80 mL Caliper Conversion Specifics
corey
107
I've got the calipers ground down and installed, and the rubber hoses test-fitted, but can't decide exactly how to bend the metal part of the lines
to get them to work. When I look at the write up here https://www.gmcmotorhome.com/commodore/front_brake/index.html, It LOOKS like they bent the lines
so that the banjo fitting is at a 90 degree angle from where it began. Can anyone confirm this and/or provide better or more specific photos?
Thanks in advance
Corey P /
Hilliard, OH /
1974 Glacier 26'
ION Wheels
Corey,
It has been many years since I did this conversion but I can guarantee you that I did not bend the lines 90 degrees. If I bent them at all, it was
only slightly.
Do you possibly have the lines on the wrong sides? (Passenger vs. driver's side).
If you are talking about 90 degrees rotational when installing the banjo bolt, as I remember there is a nub on the cylinder that only allows you to
install them in a certain orientation. Do you possibly have the calipers reversed? (passenger vs. Driver's side)
Sorry, It has been 15 years and I do not remember much about this, and I am not near my coach right now to go look.
Ken B.
Go Clemson
The correct hose has combinsyy to ion steel and rubber. There it left and
right
On Sat, Dec 28, 2019 at 7:17 PM Ken Burton via Gmclist <
> Corey,
> only slightly.
> driver's side).
> Ken B.
> Go Clemson
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
http://www.appliedgmcrvparts.com
Sorry, it is composed of steel and rubber left and right.
> right
>> Corey,
>> only slightly.
>> driver's side).
>> Ken B.
>> Go Clemson
>> Ken Burton - N9KB
>> 76 Palm Beach
>> Hebron, Indiana
>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
After thinking about it too much..... final answer was
To just get the lines where they need to be on the coach and it is easy to see how you need to bend them.
The biggest thing is how to mount the bracket to the a-arm and route the line. Just get in there and fit it up and you will see what has to happen.
Small bend- maybe two trips back to the vice and back to re-fit to coach.
Make sure you file the casting edge on the knuckle itself. That is not documented well. The round part
Of the knuckle where the caliper sits, needs a little filing to clean up the casting. Caliper can rub there(was rubbing on a coach we did not do that
to)
Jon Roche
75 palm beach
St. Cloud, MN
The calipers are on the correct side (bleeder is up), and the casting nub is ground off. Here are some photos of how the line interferes with the ball
joint stud and cv joint currently. I am ready to take the "get in there and see what way it needs to go" approach but I was wondering if anyone had
any photos of exactly how theirs is bent. I want to learn from others mistakes / successes.
http://www.gmcmhphotos.com/photos/data/7264/medium/Capture2.JPG
http://www.gmcmhphotos.com/photos/data/7264/medium/Capture3.JPG
http://www.gmcmhphotos.com/photos/data/7264/medium/Capture1.JPG
Corey P /
Hilliard, OH /
1974 Glacier 26'
ION Wheels
I dont personally like bending prefab lines but if one must i would mount the line on the caliper, and carefully/limitedly bend the line to just
clear what i need it too.....in my opinion you risk kinking the line if you try to get to gready with it.
One thing to keep in mind is you just need enough room to clear the ball joint nut...i wouldnt care if i had to remove the caliper to put the nut on
or remove it.
Do the bend by hand, do not use plyers or the like....its probly not possible but if you could get a bending spring over the line it would help keep
it from kinking...
Take your time and it might just work out.....YMMV and proceed at your own risk.
Rich Mondor,
Brockville, ON
77 Hughes 2600
What the pics show is totally different from what I have, I reversed the banjos. However, after looking, I'm going back and refitting them. I
borrowed Zhookoff's pressure bleeder but it leaks at the seal. Inspection shows the rubber is creased here and there where it hits the edge of the
master cylinder. A new rubber mat is in the offing tomorrow. Meantimes, I can run clear fluid forever out of the caliper bleed nipples, but no
pedal. I suspect air in the master cylinder bores. Can the MC be bled on the coach? Take the lines off and fit the return tubes and pump till the
bubbles if any go away? It's level, due to the front wheels are off and the cribbing is a bit low.
--johnny
Braselton, Ga.
Yes it can....same way as a caliper....pump it up, hold pedal, open line....repeat on piston #2..then pump it up, hold etc...dont take the lines off
or youll have air in the rest of the system.
Once you get a bit of a pedal move to bleeding the brakes....i always start the furthest away from the master, then opposing front, opposing back
etc.....X pattern if possible to keep the propprtioning valve somewhat centered.
> the bubbles if any go away? It's level, due to the front wheels are off and the cribbing is a bit low.
> --johnny
Rich Mondor,
Brockville, ON
77 Hughes 2600
> --johnny
Yes, it can. We(I) did this for my friend Greg last fall when we changed out his master cylinder because at least one seal had gone out. We were
able to remove the old one, "bench bleed" the new one in place, and then carefully bleed the line at the master and he got pretty good brakes back
right away.
