As I understand it, there is no change in the physical size among the
various gears, therefore no fitment problems. What is different among the
various gear sets is the number of teeth on both the ring and pinion gears,
which results in the various ratios available. Caspro's literature would
have you believe that there are practical limitations on the number of gear
teeth to optimize strength. Not sure that current experience shows that is
any limitation, though
Paul Bartz
Sent: Tuesday, January 18, 2000 11:08 AM
Isnt there a structural problem with these numerically high final drives.
there is only so much room for gears. If the ring gear is increased and the
pinion is decreased in size seems like we would be sacrificing steangth of
the pinion gear. Any comments?
> I recently ordered a 3.70 final drive from Jim K. Should be here within
the
>next week. I did this rather than the sprockets on the strength of the
opinion
>of Kent Cooper of "Transmissions by KC". He is a rebuilder, transmissions
only,
>in White S.D. and a few of us "Greater Midwest Classics" have had our
>transmissions done there. I am very well satisfied with mine. Just a few
words
>to inform of his qualifications. Any how, I have a 3.21 final drive that I
was
>going to install with the 3.50 sprockets from Chuck Stoddard for a final
ratio
>of 3.66 at the road. After talking with Kent, I decided to go with the 3.70
>final because as he explained, it's better to have a happy engine(more
rpm's)
>and a happy transmission (more rpm's, more internal pressure). When onlyu
the
>sprockets are utilized, only the engine is speeded up. The cost to me was
just
>about a wash, so that's what I decided to do and why. Works for me, maybe
not
>for you.
> Pat 77 Birch
>> In a message dated 01/17/2000 1:48:00 PM Central Standard Time,
>> > I thought the final drive change was best now I am not sure. I want to
>> > do one of them but not both. Darren
>> Darren
>> Here is my thinking---nothing more. I honestly have no idea which is
best.
>> I wanted to take the load off the tranny and chain. So my thoughts ran
>> to doing the final drive. Thats why I did not like the Caspro system. Now
>> I dont know. Hope others speak up.
>> Take Care
>> Arch
