2nd A/C Unit
marie solace
7
In response to the question on wiring for the 2nd A/C Unit, that is not the
only problem. When I installed my new Heat Pump, It was my thinking to move
the existing A/C unit to the rear opening, but there was no support for it
in the ceiling. When I took down my headliner, I wired both the front & rear
openings for possible future A/C units and also installed 1" square tubing
to frame out the openings to hold the weight of the A/C unit. You can't just
put one up there without the required bracing. If you remove the existing
'Fan' you should be able to see if it has the required support to hold up
the A/C unit.
Tom Bradley
77 Palm Beach
