1975 GMC PALM BEACH GILBERT, ARIZONA $ make reasonable offer
Louis
201
102
43
Gilbert, AZ
This coach is in an overall very good, well above average, ready to drive, ready to camp condition. The exterior is in excellent condition and was treated to a tasteful, modern and expensive ($20000) paint job in 1999. It has been kept inside most of the time since then and still looks great, even up close, really. There is no fading or clearcoat peeling. You could shave in the bumpers if you need to. There is no fogging in the windshields. It has modern tinted living area windows, Aluminum wheels, Zip Dee awning, modern head and taillights. I just put a fresh ceramic coating on it. You will never have a problem being accepted in a RV park with this 50-year-old motorhome.
All the mechanicals on this GMC Motorhome, both chassis and coach, are now once again also in excellent ready to use condition.
I will rate the interior as fair to good. I bought this coach as a stalled interior remodel project in August of 2022. The remodeler passed in the middle of the project, and it then sat untouched in a cooled Arizona garage for 6 or so years. I finished several of the individual interior projects and returned it back into a completely usable condition, but did not complete the entire remodel as planned. The PO removed the original dinette and replaced it with a big screen TV on a retractable frame in a custom cabinet. The TV install has not been completed, but I took the brand new but 8-year-old tv into the house and it tested out fine. The cockpit and rear bedroom curtains are old but fully functional and the living area Venetian blinds could be dressed up with a set of valences. I have had a lot of compliments on the interior and tv cabinet, but personally I would prefer a dinette. For that reason, I bought another dinette but have not installed it. I see 3 options for the interior. 1. Use it as it is. 2. Finish the TV remodel as planned. 3. Reinstall the original dinette. You decide. I can include used TV antenna equipment and/or used original interior pieces with the sale.
Not wanting to risk damaging it from a dry start with old fuel and oil, I had it towed to my house where the old fluids were drained, and new fluids installed. The old spark plugs were removed and the cylinder walls lubricated with fresh oil, the engine was then turned over until good steady oil pressure was shown, new plugs installed, then started. It ran well, but instantly the expected problems that come with a 50-year-old motorhome that’s been sitting idle for a while began to reveal themselves. It had a blown exhaust gasket. I’m a FAA certified Airframe and Powerplant (A&P) mechanic as well as an Airline Transport Pilot (ATP) and began to treat this motorhome project much like I would an Annual Inspection on an airplane. My squawk list has 235 items on it that have now all been corrected. The list includes everything from simple loose screws and burnt bulbs to more serious items like the blown exhaust gasket, tires, batteries, shocks, airbags, CV axels, etc., etc. Now EVERYTHING has been tested and works (except the trip odometer) and after 1000+ miles of testing and actual camping the motorhome is once again roadworthy and camp worthy and ready for use. There have been only 2 previous owners of this motorhome before me and they have used it, enjoyed it, maintained it, modified it, personalized it, and completed MANY beneficial upgrades.
The following is a list of the upgrades.
Engine and transmission overhaul approximately 16000 miles ago by engine works of Spokane WA
3:55 final drive
Headers ceramic coated
3-inch stainless exhaust with single rear muffler
Howell fuel injection
Electronic ignition
Ragusa finned aluminum transmission pan
Ragusa finned aluminum final drive pan
Ragusa front 3 battery tray
Ragusa entry step
Ragusa door handle
Ragusa door pull
Aluminum radiator including transmission cooler
Additional transmission cooler
Stainless transmission lines
Engine oil cooler
Radiator fan shroud
Radiator rock guard
Heavy duty fan clutch
Engine heated coach hot water heater with shutoff valves
Remote cold air filter (original available if desired)
Aluminum engine hatch
Fender vents for engine heat
16000 BTU roof AC
Roof ladder
Vintage Air dual head engine AC
1 Ton front suspension
7 16 in. Aluminum American Eagle wheels with 6 new Cooper tires with date codes of 2822 or newer. Older never used always covered spare
KYB shocks
WirelessAir System Remote controlled rear suspension including air compressor
Isolation valves
T skirts
Modern bigger taillights
Modern square headlights
Zip Dee awning with stainless steel cover
Custom instrument panel by CIP (Mac dash) includes MPH, ODO, TRIP ODO (inop), TACH, OIL PRESS, AIR PRESS (left and right), OIL TEMP, TRANS OIL TEMP, WATER TEMP, VOLTS, FUEL LEVEL, VACUUM, 14 LIGHT TELLTAIL WARNING BAR, Sony Blue tooth radio/CD player, CD changer, CB radio, Duel head Vintage air AC unit, one under dash and one under couch/bunkbed, Duel windshield fan kit.
Electronic cruise control
Custom aluminum cabinets with oak doors
Custom fully adjustable cockpit seats
Custom modern tinted windows in living area
Custom galley
Microwave/Convection oven
4 burner stove under large stovetop/workspace/back splash cover
Retractable kitchen vent
2 Fantastic fans
Norcold 3-way fridge
Modern outside fridge panel
Modern fridge roof vent
Fridge compartment fire extinguisher
Intellipower 9200 60-amp converter
Ceramic toilet with a bidet
Macerator plus original gravity waste drain
Receiver trailer hitch
7 pin and 4 pin trailer plugs
Trailer brake regulator
The following is a partial list of recent repairs, maintenance, and parts used in my refurbishment of this coach. I keep a logbook, much like an airplane logbook that includes things needing to be done and things that have been done. There are 235 items currently on that list that have all been corrected. To simplify the long list, several similar items were combined into one repair such as this and that and the other light doesn’t work, all plumbing issues, all instrument troubles, etc.
Drained old fuel
Inspected fuel system and replaced hoses and components as required.
Changed oil and filter
Removed sparkplugs and checked compression
Lubed cylinders
Turned engine over till good steady oil pressure
Installed new plugs
Started engine, ran fine but had blown exhaust gasket
Replaced exhaust gasket
Replaced all 3 batteries
Installed 6 new Cooper tires
Installed 2 new old stock (NOS) air bags and aluminum cones
Installed 4 new KYB rear shocks matching the newish front KYB shocks
Cleaned and repacked all rear wheel bearings (fronts have 1-ton sealed bearings)
Adjusted rear brakes including parking brake
Greased complete chassis
Cleaned, repacked and replaced boots on steering CV and U joints
Welded frame crack
Installed 2 new CV axels
Installed new motor mount
Installed 2 good used transmission mounts
Installed new door ajar switch
Sealed up engine vacuum leaks
Cleaned and polished wheels
Clean, polish and ceramic coat coach
Sealed several water leaks
Removed inop Generac generator (you can have it if you want it)
Installed recently serviced ONAN 6000w Power Drawer generator
Changed oil and filter and a few other repairs on Onan
Repaired or replaced several lights inside and out
Completed instrument panel installation
Repaired all living area instruments
Replaced living area sidewall panels
Resealed all faucets
Finished stovetop installation
Installed new macerator pump
Repaired gravity waste drain system
Flushed waste tank
Installed new waste drain valve
Flushed freshwater tank
Repaired all plumbing issues
Installed new water heater pressure/temperature switch
Completed installation of Vintage air system
Replaced one speedometer cable
Replaced Onan hour meter. (Total time unknown)
Replaced air system high pressure lines
Replaced LP pressure regulator
Replaced Norcold ignition module
Replaced Norcold ignition electrode
Cleaned Norcold orifice, burner, and flu
Installed new Intellipower 9200 60-amp converter
Installed new isolator
Installed new trailer plug
Installed new wiper blades
Installed vacuum cleaner accessory bag and accessories
Come look it over, test all the systems, crawl around under it, drive it, make me an offer, take it home and go camping.
I’m an enthusiast of vintage transportation and might consider a trade for something interesting such as an original unrestored GMC motorhome, cool airplane (no spam cans) cool car 100+ years old or mini/micro/euro cars (no hot rods, no muscle cars).
Make me an offer on this ready to travel and camp GMC. See gmcrvforsale.com for the full description with 100+ photos and video.
Reactions: Carl Stouffer
3:55 final drive
Electronic ignition
Ragusa entry step
Ragusa door handle
Ragusa door pull
Engine oil cooler
Radiator fan shroud
Radiator rock guard
16000 BTU roof AC
Roof ladder
KYB shocks
Isolation valves
T skirts
Custom galley
2 Fantastic fans
Drained old fuel
Lubed cylinders
Installed new plugs
Welded frame crack
Flushed waste tank
I've got a '72 P337 that I think is pretty cool but I'm getting a little long of tooth for flying. Might be of interest otherwise what are you looking for in plain old cash?
The P337 is a rare and interesting airplane for sure. It's also a practical traveling machine, but I already own a practical traveling machine, a PIPER Arrow, not as fast or comfortable as the P337, but more economical. I also own a Culver Cadet project I haven't started on yet. I'm looking for something funky and fun like a Seabee, Lake, Waco cabin, etc. I will take plain old cash also. I'll PM you with contact info.
Fair enough - it's along trip for us down your way to look it over but it sounds pretty good. I have a little cash but think I need some kind of number to consider whether I want to make the drive. There are a couple of units up my way I've been looking at but yours looks to be better if I can swing it.
Ok, I'll get to work on it after the holidays. We have a micro/mini car get together on the 15th we are working on now
Congrats Louis. Somebody got a good one.
When we got home from Traverse City the NOS airbags I installed had gone bad and all the freon leaked out of the AC compressor, so I reinstalled the old bags (which actually look really good) and dropped the price quite a bit to compensate for the new issues. Even still it's a very nice coach and will be even nicer when they install the upgraded systems.
Louis - got back a little late with headlight quitting had to wait for daylight. Not a problem got a good nights sleep. Very comfy. No other issues. Got home and manual says there's sort of circuit breaker at the light switch that should reset after 40 seconds if there's a short. Started poking around - found nothing obvious then
wife came out and said headlights were on so maybe it reset. Don't know and do hate itermittents but I'll fool with it some more. Otherwise both very happy with the buggy and appreciate your help and all your work on those several hundred squawks.
