1975 26' Eleganza II Nashville TN $20,000
foundation982
4
2
3
I'm probably going to regret this but I've decided to sell my GMC motor home to downsize to bit smaller vehicle such as a camper van.
Below are the details!
Selling our 1975 GMC motorhome, It has 63,000 miles. Runs starts and stops perfectly. The RV is not perfect but this one is pretty close for its age. The Onan generator starts up and runs great. Every accessory works, Propane/electric fridge works, shower works, stove/oven works, propane tank seals and holds, water tanks seal. I did not do the work but it had a lot done in 2006. those items include-Airconditoner-Airbag setup-Viair onboard air compressor.-Alcoe Wheels-Propane fridge-Hot water heater-New charge controller when shore power is plugged in. -Stainless Steel headers-New toiletThis year what's been replaced-upgraded to 1 wire alternator-Samlex ACR-160 Automatic Charge Isolator-All rear bearings serviced with new seals and grease-New through bumper hitch from Applied GMC -New onboard water pump.-New memory foam bed All tires are from 2022I will add more photos when I have time, the RV has been stored indoors since I have owned it. image0.webp
image1.webpimage2.webpimage3.webpimage9.webpimage7.webpimage15.webpimage10.webpimage18.webpimage8.webpimage5.webp
Reactions: sandra74
Selling our 1975 GMC motorhome, It has 63,000 miles. Runs starts and stops perfectly. The RV is not perfect but this one is pretty close for its age. The Onan generator starts up and runs great. Every accessory works, Propane/electric fridge works, shower works, stove/oven works, propane tank seals and holds, water tanks seal. I did not do the work but it had a lot done in 2006. those items include-Airconditoner-Airbag setup-Viair onboard air compressor.-Alcoe Wheels-Propane fridge-Hot water heater-New charge controller when shore power is plugged in. -Stainless Steel headers-New toiletThis year what's been replaced-upgraded to 1 wire alternator-Samlex ACR-160 Automatic Charge Isolator-All rear bearings serviced with new seals and grease-New through bumper hitch from Applied GMC -New onboard water pump.-New memory foam bed All tires are from 2022I will add more photos when I have time, the RV has been stored indoors since I have owned it. View attachment 17161View attachment 17162View attachment 17163View attachment 17164
Price?
