16" Steel Wheels
chuck blanford
296
I believe the concern is hub diameter and possibly caliper clearance. The
GMC requires a hub centered wheel so that the weight is not carried on the
studs. Before I purchased my Alcoas, I had purchased an after market alloy
wheel for a Chev dually. The stud pattern was correct and they cleared the
calipers, but the wheel hub diameter was larger than the GMC hub. ALL of
the weight would have been carried on the studs.
I was fortunate in reading a timely article in GMCMM about this very
problem, and with a copy in hand, was able to return the wheels even though
we had mounted the tires. I'm sure they didn't want to be liable once the
hub diameter issue was brought to their attention.
Chuck
77 Kingsley
North Idaho
- -----Original Message-----
To: gmcmotorhome
Date: Thursday, August 05, 1999 10:17 PM
Subject: GMC: 16" Steel Wheels
>Justin:
>I hope these aren't the same ones that Pete Papas checked out. IIRC there
>was a really good reason he felt they would not work. If they do work, I'd
>really like to know.
>Thanks
> ___________
>Dave (& Dege), '76 Royale /_][__] [_] | "SR JAMES"
> Santa Barbara, CA *0-------OO--* (our hobby)
Justin:
Thanks
___________
