1 Ton Conversion Question
Tom Katzenberger
795
287
63
Gang,
I know I've touched on this in the past and there are differences of opinion, but I am at a point where this old coach needs a total suspension
rebuild as all the rubber is all original(1977).
I have 2 spare knuckles with grease fittings. I just don't know how old they are. It appears that the 1 ton would be cost effective. Many seem happy
with their 1 ton conversions. It would speed up my rebuild, plus and minus some of the positives and negatives. Many say if they were at the point at
which I am, they would do the one ton conversion. How happy are those with the one ton? Would you do it again? Would you do it if you are in my stage
of reconstruction? What are the differences in Manny's kit and Applied's kit? Can you get the kit in Polyurethane Bushings?
As always thank you for sharing your thoughts and opinions. Also thanks for respecting those who have differences of opinion.
Take care,
Tom
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
I have Manny's 1-ton on both my coaches and am very satisfied. I do not know the differences between the two kits. If you still have OEM brakes, you
will also get an immediate improvement in braking. I think that improvement in braking alone is worth the cost and work to change. I have not
noticed the difference in steering/handling that others have noted, but it may be because I just drive like an old man (which I am!).
Hope this helps, JohnS
John Shutzbaugh, Vacaville, CA, ncserv;
77 Eleganza, bought it new, can't blame PO; and
78 Buskirk stretch, "What were we thinking?"
Tom,
I installed the one-ton from Manny's first production run, so had a few
glitches to work around that were subsequently eliminated. I've always
been very satisfied with it. The torque steer than some complain about has
not been a significant problem for me -- perhaps, even with my Cad500 and
3.55:1 final drive, I don't accelerate from a stop as enthusiastically as
some. :-)
Since I've never had to do anything to the front end since installing the
one-ton, I can't address the ease of bearing replacement -- I'm just hoping
it will be as simple as advertised.
Not a lot of information, I admit -- Simply, "I like it."
On Sun, Feb 21, 2021 at 9:36 AM tomkatz3--- via Gmclist <
> Gang,
> Take care,
> Tom
The One ton from either comes with the Uathane bussing in the lower arms
on;y as the top needs some dampening from the rubber
Additional Caster are built in the lower arm.
You need the NEW Specs on alignment as the ones in ALL the fancy machines
are for Bias Belted, not the Radial tires we run.
There are lot of difference in the tires.
On Sun, Feb 21, 2021 at 9:29 AM Ken Henderson via Gmclist <
> Tom,
> some. :-)
> Ken H.
> > Gang,
> suspension
> happy
> minus
> at
> with
> stage
> > Take care,
> > Tom
http://www.gmcrvparts.com
I've had my one-ton for about 10 years now. I really like the superior braking power from the larger rotors and would not go back to OEM.
As far as the steering geometry, I don't really notice it, its not a rally car! The front-end loading on the motorhome changes very little so the
suspension does not move far from center point.
Maybe someday new knuckle casting can be made with proper ball joint mounting points so this issue will go away.
I got the JimK kit before I heard about Manny's kit. From what I gather and my experience, JimK's kit comes with everything you need for the
conversation, whereas with Manny's kit you need to source your own brake calipers, shoes, tie-rod ends etc.
Just my experience.
Bruce Hislop
ON Canada
I have installed too many 1 ton conversions to remember how many. Both the
Huber version, as well as Manny T's. So far, I have had one known failure
that I am aware of. It was a recent install, and it was a torsion bar
socket failure. A faulty weld that allowed the torsion bar to unwind. It
was a Manny T conversion, but it could have just as well been a Hubler..
Not a nickle's worth of difference between the two. The bar was wound up to
the end of the adjustment threads. The lower control arm was promptly
replaced under warranty, and new 19% stronger torsion bars were installed.
Better than originally fitted. One big advantage of the 1 ton, is the
bigger brakes. All new bushings throughout are also a big plus.
Salem, Oregon
On Sun, Feb 21, 2021, 12:24 PM Bruce Hislop via Gmclist <
> Just my experience.
> Bruce Hislop
> ON Canada
You say all the rubber parts are shot. There are only 8 bushings (and the stabilzer links and bushings which is minimal) What about all the hard
parts?
2 upper ball joints
2 lower ball joints
2 drag link ends
2 inner rod ends
2 outer rod ends
Idler
Relay
I would check all these hard parts and then make my decision.
You already have knuckles with fittings that will outlast us.
Some of these parts apply to both situations, so figure that into your total cost.
I see no advantage in replacing parts that are not bad.
John Lebetski
Woodstock, IL
I replaced ALL of the rubber bushings with urethane years ago. It was not a bad job. Bushings pressed easily with a vice and used no special tools or
spacers. I spent more time sandblasting and painting the control arms while I had it apart than I did pressing bushings.
Tom,
I just installed the Manny tranny and the Manny 1 ton and it went together perfectly. make sure you get your torque wrench out. Regardless of the
opinions on this forum, I have had no issues with it. the ride height is exactly where I want it and the initial set up was perfect to then drive to
the alignment show. I replaced "everything" up front to include stainless steel brake lines and in my opinion Mannys' set up is stellar. I would call
him to give him heads up before you go pick it up. he has parts in multiple storage units at his home and he will assemble some of the pieces before
you leave.
Of course you can purchase from whom ever but I am totally satisfied with the new set up. Oh the wheels are in alignment as well from front to back.
As wise man told me:
"if you don't upgrade the coaches with todays technology the coaches with be stuck in the past"
Manny Trovao
mailto:mannystrans
Manny's Transmission
San Jose, California
1974 GMC Sequoia 26'
Ken,
Is there a kit for the complete poly bushing replacement or did you order separately?
I am looking into Jim and Manny's kit. Are they both Hublers design? I also found that my donor coach has grease zerks in the knuckles which may
change things a bit.
Thank everyone for your input. The beautiful thing about these coaches and there owners is that no two are alike. None all wrong or none all right,
but all heading in the path of their owners dreams.
Thanks again,
Tom
> Ken,
> which may change things a bit.
http://bit.[/color]
> right, but all heading in the path of their owners dreams.
> Thanks again,
> Tom
The knuckles on the donor coach have zirks? If you know the previous owner, contact Dave L to see if those are his rebuilds. If they are, IMO this is
a no brainer. Swap them over to your rebuild. Grease them up good with Mobil 1 grease and drive it. With a greasing every 25K or so, they will
probably outlast you and Oki. JWIT
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Thanks again Larry!
I will go through the paperwork to see if I can find out any info. If no luck I will call Dave L. Upper control arms are off. I am trying to locate my
pork chop tool to remove the lowers. If all goes well I will switch out by the end of the week.
Take care,
Tom
